Not a huge amount of progress, but finally my 114mm hole saw arrived, and as such I christened it with a nice hole in the base of the case, for the radiator!
The radiator on the other hand, got a bit of the PlastiCote treatment, and is now a much more fitting white
Next job is to fit the radiator and the fans, and then start the arduous task of wiring the thing up!
It's only a very thin coat on the fins (so as to not lower airflow much). I had the fins masked, sprayed the body, then removed the masking and did the worlds thinnest coat of white (you can still see the black on the fins if you look closely).
That, and the 720be x3 runs pretty cold anyway, it's certainly not been hindered by the whiteness!
