Project: PITA (Lian Li A05b new build)
Thought i would share my new build with you guys, its the first time i have modded a case so please be gentle.
First of all this isnt really a project, its just a series of mods performed on a Lian Li PC A05b case, the hardware going into it is the same as in my signature but the Arctic Freezer 7 has been replaced with a TRUE Black edition.
You will read as to why i have christened this little project PITA (Pain In The A$$) as you read through the log
Now for a bit of back story:
I fell in love with this little case after reading the [H] forum thread dedicated to this little chappie and decided there and then that i must have one, about a month later i was perusing the Auction site and came across one which was "In as new condition with a few marks and enlarged reset switch hole", i emailed the seller and asked for the photographs of the damaged areas, what came back was nothing to worry about.
We agreed a good price and i purchased the case, when i received it there was more damage than had been shown and the front panel was a completely different one.
Basically the front panel had a huge hole gouged out of it and there was scratches all round the hole, the side panel was scratched to bits etc etc (PITA), apart from that it was in excellent condition.
This all happened about 7 months ago now, and since then i have been on the prowl for little bits and pieces to add to the case and after accumulating it all i finally started the build on friday 3rd Oct.
Here is a list of all the parts i already had, managed to acquire or steal from work
Lian Li PC A05b Aluminium Case
Lian Li G50 Side Panel (The vented one)
Lian Li G50 Side fan and assembly
Sound Damping Material
Xilence 3.5" Fan Controller
TRUE Black edition (Lapped)
Intel E2200 (Lapped)
3 x Xilence Redwing 120mm Fans
2 x Vandal Switches (Power-red ring, Reset & HDD activity-Red Dot)
Gigabyte GA-P35-DS3R
Gigabyte ATI Radeon HD 3850 Pro 512MB
GeIL 4GB (4x1GB) PC2-6400C4
Coolermaster Real Power 520w Modular
Building Time:
First thing i did was to look at the front panel and see what i could do about the messed up hole and scratches around it, the only thing that i could easily do with my limited tools and skills was to make a cover of sorts, ideally this would have been made from Brushed Aluminum same as the case etc but i didnt have any and didnt want tuy a panel just to cut a couple of inches out of it.
Anyways the wife does some kind wierd hobby and she had some black acrylic lying around so i stole a piece of that and cut and shaped it so that it would cover all of the offending areas (I know its not ideal but until i find something else it will have to do)
I then cut out the material that the circuit board for the old switches would have attached to so that the vandal switches had decent clearance behind.
Next up was Cutting a hole in the bottom of the case so the PSU could draw cool air into itself, this was actually much simpler than i thought, i just got a CD, marked round it and cut using my trusty Dremel.
I then trimmed the hole with Rubber window trim with an adhesive bond already in it, this gave a decent finish, to this added the mesh guard from the rear of the A05B.
Building Time:
