Project: PITA
consider getting this for the nb.
http://www.thermalright.com/new_a_p...er_hr05.htm?art=MTQyMywxLCxoZW50aHVzaWFzdA==#
should help with the OC a bit
i have that, with the TRUE on my gigabyte DS3R, they do touch (just) but it fits
you'll have to use something else to hold the fan on though, the clips for the TRUE won't fit with that heatsink in place
at the moment, my fan is just resting gingerly on the TRUE, I need to put two fans on like you, and i think i'll use 4x elastic bands going diagonally over the fans
@ Pedrochop,
I have read that the E2160 is an excellent clocker, but i also know it can be very much luck of the draw.
@bledd,
I had a look at that NB cooler a while back...do you think it makes enough of a difference to bother with it?
What kind of performance are you getting from your system with the TRUE and the NB cooler installed?
Sorry for the questions, i really have got the bug!
better off asking other tbh, i've not pushed my clock yet, it's just sat at 3ghz (q6600), not had time to fiddle
temps are in the 20-30's though :) dead happy with the TRUE
