Project: Plasma Cannon
Sponsored by
Hi all got some progress after a busy Christmas. So as my previous post the painting didn’t go completely to plan so decided to send it off to be professionally painted.
Here are the photos I sent off for some quotes as you can see is not the best results even some of the items and the fully coloured parts are too dull. The beer can was just for a size compair :D
So before I sent the parts off, I made a few adjustments to the frame so that it could be sprayed as one piece without the need to mask off the plastic insides
There was also some various masking off on parts like this Aquacomputer res. Please excuse the water on the lenses.
So all boxed up and ready to go.
And Fingers cross the results are going to be really good! (EDIT! Stuff is painted and collecting it tomorrow!:D)
During the holidays Santa arrived aka DPD with an overclockers parcel. That contained some goodies! But some still to follow once I raise the funds needed!
The Cable Tidy
This part got a few tweaks from the original for example the spacing in-between the rings have a increased gap and after a suggestion from you guys to improve the method that the pipes join the rest of the cable tidy.
So this is you guessed it made of aluminium and brass. I got myself a small bolt cutter to make this a little easier.
With the 50mm diameter aluminium pipe with 2mm wall I cut it down the lots of 25mm section then cleaned them up on the milling machine.
Next add a few holes so I can fix them together.
Then after a bit of cleaning up they look really good.
Ok to sort the chain I cut it up into 5 links each and then used pliers to fit them back together.
So here is how the first section turned out.
Now just a quick test out the pipes and cables fit, all is good even the chunky DVI threads through with a little space all round.
Later on...
The larger ring is designed to hold the main pipe intake hopefully with some boiling water I can get theses pipes to sit nicely and retain their shape. If not I can use a elbow join connector.
Far later on... The remaining links I will add once the main case is assembled so I can better judge the amount of links needed.
While the panels are away being pained time to do a little electronics this is the controller for the Blue LEDS contained within the side panels the larger board is made for the fixed panel. And then the smaller one will be on the other side with connectors so it can be easily disconnected if needed.
Much more to come follow stay tuned.
Sponsored by
Hi guys Got the parts back this morning and want to share some photos :) Hopefully get it assembled soon
so what do you think?
I think I speak for a lot of people here - many projects have an idea.... never get started/ get started and binned and yet here you are pretty close to completion. Dedication and the skills involved are unreal.
Looks absolutely perfect, just the right shade. Not too glossy either, at least as far as the photos go?
Thanks Guys! I Really want to get it assembled but I really should wait a few days for the paint to really harden. It is a little bit glossy but im fine with that.
Whats up with that soda can?
Well thats one of my first scrach build pcs you can just make out the CD drive and some of the ports ontop (I hope to make another sometime). Its fully working last time I turned it on a few years ago. The sofa well thats just a sofa... At the moment....
Amazing project this, (and the coke can one sounds interesting as well). Look forward to seeing this come together. Quite like the glossy red finish.
I simply don't possess the vocabulary to describe how incredible this build is. Your skill is evident not only in the concept - but in the machining, fitting, design work and functional dedication to the source material. I really hope I can catch this at an event, as I desperately want to see this thing in person. Awe-inspiring.
Hats off to you sir, I've really enjoyed following this. Your Ideas and skills are off the chart. Simply excellent, thanks for sharing this with us
