Project- Power PC with antec side project
Project- Power PC
Status- Day 6 epic failure
Parts still required- psu
number of swear words uttered to date- 612- the psu blowing added a good few hundred
well i made a fatal mistake last week and indulged in some drunken ebay bidding.
the result being I ended up the owner of 5 powermac G4s
now having always wanted to build a G5 powermac pc i thought this would be an ideal opportunity to build something that little bit "different"
so here we are at the beginning of Project- Power PC
final aim
G4 mac case with a fully watercooled sandybridge/ivybridge gaming system running 24/7 with fancy lights and snazzy looks
Tools
whatever i find in the shed along with copious amounts of chemical metal
this is what i picked up
i have a total of 5 power pcs one of which has been spared due to being a bit "tasty"
this has been saved
its a MDD(mirrored drive door model and comes equipped with 2x 867 mhz cpus and thanks to a bit of canibalisation from the other macs a rage 128 pro gpu and 384 megs of ram (it rocks)
slighty better pic, This is taking over my daily duties once i install osx 10.5 on it until such time as project pile of crap/power pc is completed
now these macs seem quite straightforward to work with look at the nice easy catch for opening the sides up
and the guts of a mac
this is the MDD which i am not using as the backplate is totally wrong for a atx layout so i've moved onto one of the lesser g4s
I got a bit carried away at this point and forgot to take pics so heres an empty powermac G4. having dinner then the dremels coming out,
hopefully have a mobo test fitted this evening.
one stripped G4 case, see how easy that was
now to cannibalise my daily rig for a psu and get stuck in
oh btw any ideas/suggestions/criticism is all more than welcome, if you think something would work or look cool then tell me
Project- Power PC
final aim
Tools
this has been saved
