well i managed a sneaky wee half day today
so off to B&Q i popped and bought this
woohoo speedclic dremel malarkey ahoy
but first things first coffee
some girly safety tips with the dremel that i ignored
and then after all the huffing anpuffing and going and buying new dremel bits i realise the bit i need to cut out is actually rivetted on.
I feel a complete muppet now
broke the drill out and 2 mins later
mobo in place
i could cut that middle support but i dont think i'll bother just now. worry about that once its all up and running if i dont end up going for a standalone soundcard
more liney up shots
and standoffs drilled into place
now rather than gluing the standoffs in i went for chemical metal
epic name
also sorted the loose backplate
stripped my daily rig for some bits
and bench tested the mobo (it works fine btw
got somore more measuring done
and now my standoffs are tightly in place i've started a quick rebuild to make sure things clear
off to the inlaws for dinner shortly so more piccies when i come back
