Sponsored by ;
( www.tacens.com )
Tacens Ventus Ice 120mm fans
( www.techflex.com/prod_PTN.asp )
FlexoPet 'Uptown Purple' Braiding
( http://www.phenoptix.com/shop/ )
LED lighting supplies
Hi all.
New build time, so welcome
Not sure how long this build will take, but it'll keep me busy anyway.
Nothing hi-tec in the hardware department, so attention to detail will be my main priority.
The Case :
Doesn't need an intro. , a MM U2 UFO.
Never worked with one before, so looking forward to it. Bit scratched at the moment, but not a problem.
The Colour :
Thanks to Craig / Madcat for the piccies.
Hoping to match the purple metallic finish in the above pictures by stove enamelling.
The Hardware :
Q6600
Asus Maximus Formula SE
4g OCZ Reaper
Nvidia GTX 285
Asus Xonar D2X
74g Raptor
500g Samsung F1
Watercooling :
Single loop - CPU, NB, SB, Mosfets + GTX 285
CPU Block - To be decided
Swiftech Komodo Water Block for gtx 285
D5 vario + EK top
Clear Dual bay reservoir
XSPC RX240 Radiator
XSPC R120-T Crossflow
Compression Fittings
White Tubing
Purple coolant
Smoked/Tinted Acrylic Windows.
Tacens Ventus Ice 120mm fans.
Stealthed DVD drive.
Stealthed Rheobus fan controller.
Possibly some custom Acrylic work inside, similar to my Dark Water build from last year, plus whatever else springs to mind along the way.
Thats the plan anyway.
Thanks for looking.
Mark
