More braiding of tubing, have moved on to 2nd loop for the OCZ Flex memory ;
Had some fan grills cut.
The inner ones here are backed with standard/small hole MeshX, so the back of the radiator is not visible;
All the other fans will be grilled, but will be backed with white Hex, or honeycombed, mesh to allow airlow and not to obscure the fans.
A couple of semi-darks;
Nice tidy work area
Thanks for looking, back soon :thumb:
hey, just a ad confused about the leds, how have you powered them up (like connected them to what?) thanks
Straight to molex, they have a resistor inline for 12v.
I was going to splice them onto the fan power cable, but that would mean that they would dim if i lowered the fan voltage too much via the controller.
Cheers.
and are they just setup in series after that?
Not so sure about those white mesh backings behind the fan grills though - looks very restrictive.
Thanks for the positive comments above, keeps me keen to finish it
The mesh in the picture is for the internal shroud only ( more to hide the radiator behind than for performance ).
The mesh for the intake fans is a different size, to allow better airflow, it has roughly 2.5mm holes and better spacing.
This stuff, but will be sprayed white :
Cheers.
I like the looks of the fitting you have on the EK 3a's - are they adaptors with a compression added or a complete unit?
