Are those the fittings with two o-rings to seal the tube?
I thought about doing acrylic tube between my cards but gave up on working out the lengths, got confused with the slot distances also!
Have you test fit the SLI bridge? It is a good way to check the distance also, I use it to hold the cards in place while linking them up.
Also, do you laser cut your own acrylic or ordered it somewhere?
Keep up the good work
