- 23 Sep 2009
- London
Just bought all this:
My basket at Overclockers UK:
Updated Post #2
I almost bought two 1080 Ti's with RGB Block's!
Since I'm mounting a rad at the bottom, I can't use the GPU vertical mount. Especially if I go SLI.
A single 1080 Ti vs 980 Ti's in SLI for gaming isn't a big enough difference so, two options:
* Stick with Dual 980 TI's in SLI
* Go for GTX 1080 Ti's in SLI (and keep the 980 Ti's in my X58 TJ07 build which I'm going to hard line as well)
- 1 x EK Water Blocks Filling Bottle (1000mL)= £5.99
- 1 x Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) - Value Bundle= £73.99
- 4 x Monsoon PETG Tubing 13/10mm (ID 3/8" OD 1/2") 4x90cm - Clear= £10.99
- 1 x EK Water Blocks EK-FB ASUS ROG R6E RGB Monoblock - Nickel= £104.99
- 1 x Thermal Grizzly Kryonaut High Performance Thermal Paste - 5.5g / 1.5 ml= £13.49
- 1 x Monsoon EV2 Compression Fitting For Hard Tubing 3/8" x 1/2" (11.8mm-13.2mm) - 12 Pack - White= £52.99
- 1 x Monsoon EV2 Compression Fitting For Hard Tubing 3/8" x 1/2" (11.8mm-13.2mm) - 6 Pack - White= £28.99
- 1 x Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)= £13.99
- 9 x Phanteks Halos 120mm RGB LED Fan Frame - Black= £9.95
Updated Post #2
£20
(incl. VAT)
