After deciding on not going for i7/watercooling/eyefinity etc route this year, posponeing it till end of next year, i still wanted to ich the upgrade bug so decided on somthing small and fast
Intel I5
Asus Maximus GENE III
H50
4Gig Patriot Ram
Samsung 1tb HD
Corsair 520w
Powercolour PCS+ 5850
Zalman ZM-MFC1 fan controller
1x92mm
2x60mm Fractal fans
2x120mm Noctua (how to prononse that?)
All compressed into the Lian-Li 351b
Parts
First mods needed
Chopping up the fan to make it fit
Cable routing
Finished
Took about 3 days of cazy work to finish, but was by far the most fun build i have ever done. Finding inventive ways of making it all fit together and getting some first hand experience with case modding (thats why some of the works abit fubar
Will start on overclocking soon temps seem great at the moment though
. Might even try and fit some watercooling in at some point
Edit : bigger imagiz
Intel I5
H50
4Gig Patriot Ram
Samsung 1tb HD
Corsair 520w
1x92mm
2x60mm Fractal fans
Parts
First mods needed
Cable routing
Finished
)Will start on overclocking soon temps seem great at the moment though
. Needed to order more rivets too so will have to wait till mid-week to put it all back together
