- 25 Dec 2009
- London, UK
nThis build was originally going to be built in an TJ07, but after a lot of debating i knew that i wanted to build a small powerful rig inside a smaller case than my current case which is an Antec 300 which i decided was going to be the Silverstone TJ08-E.
The Parts:
i7 3930K
Samsung Green Memory 4x4GB
EVGA GTX 580
TJ08-E
ASRock Extreme4-M
Asus Xonar DX (First soundcard
Crucial M4 128GB SSD
Samsung F1 1TB x2
Samsung F4 2TB
AX850
IcyBox 3-2 Bay
Noiseblocker 80mm XE2 fan
Prolimatech PK-1 (30g)
The monitor is a 16:10 old VGA which my eyes can handle with the brightness (I've tried like 5 different monitors)
Watercooling Parts:
Apogee HD Gold Plated (LIMITED EDITION OH YESS
Hydro Copper 2 Waterblock (Best looking waterblock out there!)
OCOOL MCP655
XSPC Tank Res (Mounts D5 Res)
Scythe AP-15's (Will use one for now)
Silverstone AP181's
Magicool 180mm Radiator
Magicool 120mm Radiator (Slim)
T-Balancer BigNG (With NZXT 2x3pin)
Thermochill PrimoFlex Pro LRT 3/8" ID - 5/8" OD Blue Tubing
Thermochill EC6 Clear/Clear
Bitspower 45 Degree Angle Fittings (Silver Shining)
Bitspower 90 Degree Angle Fittings (Silver Shining)
Bitspower Matt Black Compression Fittings (On CPU Block)
Bitspower True Silver Compression Fittings (On everything else)
Here are some pictures of the stuff that i have right now. However the fittings, a radiator and some other stuff have not arrived yet.
More pictures will follow... (Sorry if the pictures aren't what you were expecting it's because i'm using a iPhone 4S as the camera XD)
The Parts:
i7 3930K
EVGA GTX 580
TJ08-E
ASRock Extreme4-M
)Crucial M4 128GB SSD
Samsung F1 1TB x2
Samsung F4 2TB
AX850
IcyBox 3-2 Bay
Watercooling Parts:
)Hydro Copper 2 Waterblock (Best looking waterblock out there!)
OCOOL MCP655
Silverstone AP181's
