Project: Small, Powerful & First Time Watercooling
ahhhh did not see the 240 rad as it is not on your build list (or i am being blind).
i only saw the 180 and 120, flow rate and fan rpm will also affect heat dissipation.
New picture of bitspower matt black fittings on waterblock, i've ordered some wrong 45 degree fittings, so this build should be completed by later next week just waiting on the other stuff to arrive now.
I have all of the fittings etc, i'm going to start building it tomorrow, just need to go to halfords and buy some de-ionised water to help clean the radiators and i will all set.
Pictures will be coming soon!!!
I've built it, but i've run into a snag, i'm currently on air, because the Icy Dock 3-2 bay i was going to use is, too long and is hitting the power supply so I've bought two Nexus Double Twins which i will use for putting my hard drives in the 5.25" bays.
Also i need to get a new monitor which has DVI as my two VGA monitors have problems with scan lines, the build will be done by the end of this week, once the double twins arrive i can finish it off and set the watercooling up, i have the fittings etc it's just waiting on the hard drive adapters now.
