Looking very slick and well-crafted. What grade of aluminium are you using btw? Are you using mixed grades of aluminium?.... I'm looking to see how they anodise before I get mine done! At the blistering pace you're going you'll be anodising before me...
Thanks Monkey
, the bars are grade 6063T6 & the sheets are 1050AH14.
Found what I'll need for masking the helicoiled holes, they are like ear plugs but made from silicone specially designed for the job
Been going at a good pace but I think I'll pass on making a physical update today & let my energy build back up
, I got the replacement sheet of aluminium ready & waiting but I ordered some better jigsaw blades so hoping they come tomorrow, if not then I might just get started on the final side panels, I should be starting with the fretsaw really to get the pci/io piece made but I'll probably get around to that in less than a week
I have however thought up a much better looking & way of mounting the fans around the mobo, was going to keep it secret though until I've managed to make at least 1 of them, it's a sweet idea in my head so hopefully it'll work as I imagine it would
, ordered 3/16 inch round bar for these.
Also the aluminium case feet I ordered & planned on modding them, I've scrapped that idea because they take m8 bolts & I got some m8 countersunk bolts & they are way too big & blompy so decided to order some 2 inch round bar & I'm going to make them myself
sorry Bill for using a rough design of yours hope your ok with that :worried: I do plan on adding some forms of detail on it too so it's not just plain, I have a plan of using the drill press like a lathe with long full threaded bolt & nuts lol should be interesting, I have my doubts about this one but it's worth giving a try
