Hmmm really don't know when it'll be complete, depends on how the pci piece & mobo mountings go, I'd say that is the most important part to get spot on so I'm taking my time on it, pretty much just focusing on 1 bit at a time, I'll get a jig made up today & then leave fixing it together until tomorrow, my right hand has grown from all the filing lol so a day off should helpHow long you think it will be now, starting to look better than it did when it looked awesome, so i dont exactly know where that leaves it
Had any ideas for another project while working on this one?
, but I really want to do a retail case mod for a change as I've never done a forum displayed case mod & with my newly developed skills & knowledge I think I could do something pretty sweet & to be honest it could work out a lot cheaper to do, big old case off ebay or something could be the way I go for that or a cheap case elsewhere, preferably aluminium though
.Thanks Judgeneo, I didn't jump in at the deep end on scratch building, started off with basics like cooling mods & windows etc but went straight from that to scratch builds, was rough for my first 2 but after that it started getting easier, I could recomend some starter tools if you wantSubbed a while ago. Great stuff here mate, seriously tempted to splash out on some kind of case project when I next build a machine
so I have the 15mm m3 countersunk bolts & the m6 countersunk bolts for the case feet (wanted to replace the standard bolts for countersunk ones) but thinking about it I might go with the easy option of using the stock bolts, undecided on that
.Great work as always mate.
Now maybe I'm being a little thick here, but is that definately the right way up?
Looks to me that the piece with the slots should be at the other side if you see what I mean?
Edit: looking at your last image in post 256 above, to me that is the correct layout?
LOLGreat work as always mate.
correct you are, when you mentioned that I looked at the pics again & then went over to check it out & yep, put the slotted 1 on the wrong side, just glad I can LOL about it as I just took it off the wrong end & put it on the correct end & all is good
, I had them dismantled while I was filing the inside edges of the none slotted ones & must have put it back on the wrong side, d'oh
thanks for pointing that out though mate before I took it for granted that it was right
, but LOL
.LOLI noticed that too and I am glad you said it before it as I thought I was going mad. I actually spend the last 1minute looking at my rig and the image to see if there was an obvious reason.
it's sorted now but those pictures will probably get similar responses so I better update that alls ok
.LOLcorrect you are, when you mentioned that I looked at the pics again & then went over to check it out & yep, put the slotted 1 on the wrong side, just glad I can LOL about it as I just took it off the wrong end & put it on the correct end & all is good
, but LOL
A thumb with 7 fingers lolIs it just me or does the pci/io panel look like a big "thumbs up"?
Great work btw, you have put an amazing amount of effort into this.
still want to get it all anodised but I'll have to paint some parts matt black the rest I should be able to get the helicoils out for while it gets anodised, I figure that is the best solution
.Would be a good solution to use adhesive to put them together but I want to get it anodised so that's out of the question really, to be honest all the prep work to have things ready for anodising seems a lot of bother & interferes with the build quite a lot especially with things like helicoils or inserts so maybe a clear primer, then a candy paint & then a clear lacquer is what I should be aiming for with all this.I'm just glad you hadn't glued it all together - that would've been a nightmare![]()
I tried, I failed at making my own wish it were billet pci/io piece lol bleep happens, 1 of the bolts snapped in half & is stuck in the piece & the hole is countersunk so can't hide that & can't accept such a big imperfection so I drilled a spare pci/io piece off an old case & I'll go with that now, 2 things I'm gutted about: 1 the amount of time ultimately wasted on making this part. 2: it was starting to turn out awesome.
Surely you can remove the bolt by buying some very strong glue, and glueing the broken end of the bolt onto another smaller bolt. Then unscrew it out? Araldite should do the trick, or am I missing something?
Looking great, just needs a few bumps smoothed out. Little suggestion, although not sure if it would work - what about filling the holes with solder? You could use flux on them first to give the solder something to adhere to, and then sand it smooth again.
Might be worth trying on a sample piece.
then I'll consider things that could be done, the idea about the solder doesn't sound bad to be honest but I have no flux
.Looking great, just needs a few bumps smoothed out. Little suggestion, although not sure if it would work - what about filling the holes with solder? You could use flux on them first to give the solder something to adhere to, and then sand it smooth again.
Great project to watch develope! Now that you have the pci/io plate in place in your last photo, you can really see the scale of the project! ITS HUGE!!!
Much kudos
Yeah that last picture makes it look gigantic lolGreat project to watch develope! Now that you have the pci/io plate in place in your last photo, you can really see the scale of the project! ITS HUGE!!!
Much kudos
.I decided to leve the broken bolt in thereI don't think you can solder to aluminium - it's too reactive and forms an oxide barrier too easily. And welding aluminium is tricky as the temperature difference between hot enough to just about weld, and a molten pool of aluminium, is quite small iirc.
Wayne - if all else fails would it be possible to blowtorch the aluminium to heat and expand the thread around the bolt and try and unscrew it with some pliers - looks like if you took the top piece off you could get a bit of bolt to grip onto?
Or just remove and remake the top sheet of aluminium, could even dremel the bolt down to as near as level with the second aluminium sheet as possible and place the top bit on with a little divet cut on the underside if needed so it sits flush...
The PCI bracket looks awesome btw - are you planning to paint it afterwards?
I'll just use some body filler to cover all the bolt heads & the failed hole & then paint matt black
but getting it mounted to the case is the current priority, then getting the outer edges nice & then paint
.The last picture looks crazy for the scale of things but it'll look very different once the mobo is in & the psu & the fans, should look fairly cozy once the hardware entersPretty much this!
I mean it looked big before, but jesus!
Also, liking the shot of the wd-40 for scale.... the one thing every man should own!
kd
or at least I'm hoping so
but I just ordered a new one so hopefully it will be here soon
