Thanks CurunenWow, this is some nice work!![]()
.That's some serious dedication if you buy stuff from B&Q.
lol been meaning to go & get these clamps for a while now
.This is what the rods are for, something solid to bend the acrylic against
Made a start, mounted, drilled & tapped an angle bar for the acrylic to attach to for the bottom end, if I get chance tomorrow I'll finish off placing the cut down rods, cut a long thin strip of acrylic, bend it against it to find out precisely how long it needs to be & to see how good a curve I can do, then cut the acrylic piece & get it fixed on
.Now I'd better switch over the motherboards
well it will now other than a possible variable of the sata cable holes but I mod so could easily tweak things if or when the time comes
