Project: Stylish productivity setup
Hi Cheetah,
was wondering if you could post up a photo of the Kozuti cpu heatsink and your velcro'd HDD?
I'm using an Asus H77 mobo (instead of the AsRock Z77 mobo you used) and with the Kozuti installed, I cant even velcro mount my 2.5" HDD inside...
squeezing both in is doesnt seem likely with the Asus board, so I may switch to the AsRock if it fits
thanks
Hi Cheetah,
thanks
I'm going to replace the TIM today....been noticing the noise more in this heat when it starts to do anything....idling its still pretty quiet though.
I will get some pictures for you....its a tight fit i'll agree but I can just about get it in. (Not puns intended)
EDIT:
If you are using the stock HSF you can fit everything using the standard mounts IIRC....don't quote me on this though!
