Project Terran
Looks great - love those GPU blocks
Think I'll be sticking to heatkiller's for future gpu's. They make the EK blocks I used to use look pretty normal and I have had some good ones like this beastly 6990 block.
I was looking into lighting the main case area but realised fans could also be used so sourced a 25mm spaced PA120.3 (£30), this will be going into the roof coutout and have some AF120's on it. Temps and noise are fine but it seemed a shame not to use the cutout. Have also got an LED for the reservoir and some more hose coming. Wish I had some more cash and I'd make the move to solid tubing, next time hopefully.
great build JeffyB, but is it the camera angle or is there a slight kink in the tube between cpu and gpu? might need to get an angled connector to put less of a bend on the tube?
I think there was in one of the photos I took, I moved the Sli bridge up one slot and it allowed the tubing to curve nicely without kinking. Will be redoing the tubing when I get the second rad, I may even go dual loop again .
Have used Tygon, primochil and masterkleer all clouded. I have used the xspc hose a few times, stays nice and clear.
