Project Ultima [Build log]
have you decided what colour fluids you're going to use?
it's got to be black and white surely haha
@jimbaw, The colors will be just like in the drawing.. So green and orange, I just haven't decided will I use pastel, regular or UV... It will be green - cause of Gigabyte Sniper board, and orange - cause EK was the first sponsor to confirm their sponsorship and I will use most of their block, pumps and rads, so it will be as a tribute to them, and it will of course look nice next to green :)
@colinmcr, Thanks, they are just superb :)
And a little update, I will start posting pics of woodwork tomorrow ;)
ah ok that's fair enough. I thought it just a mock up.
yeah it'll definitely look nice
Thanks guys !
And finally lets start with actual work on the build :)
The build idea started when I decided to take apart some excess furniture from plywood, and I realized that I have enough to build a crazy system I always dreamed off... So, there were 2 ideas in my head, desk or wall-mount?
Both ideas were good and with rads on the other side of the wall, but at the end I decided not to go with desk idea just because of "leg space problem" (cause I'm tall and I need my leg room) and difficulty of draining (cause I often change components and draining the desk is very difficult in regard to a wall-mount, where you can see from my plans how I handled it).
So, lets go... These are roughly cut boards to size by my friends at Total Design Bor
Leftovers :D
And then came the assembly of frames, motherboard panel and the desk part itself
And the rest of boards that are waiting to be drilled and assembled
Well, some pics got lost when I updated them, so here they are now :)
This is the cover for power cords extensions, 3 of 4 vertical panels and cable cover (behind the monitor):
Seriously you are working in flip-flops? Brave man, watch you don't get any splinters ! ;)
Progressing well already nice work man...
That's not me, it's a worker in a shop I went to get this panels cut, and that's word for word exactly what I said to him :D
Hey guys, I'm baaack ! :D
I had a great time on a vacation, but there were some bad news when I checked in with my sponsors.. :(
So I'll come back to you when we straighten things out in a couple of days or so..
Welcome back !
The renderings look amazing ! Really wish i had the skill / programs / patience and knowledge to get renderings done for my project.
Welcome back !
Thanks, I actually did't have "the skill" for it, and I tried to find someone to draw it out for me.. But, none of people I encountered wanted to do such a simple and time consuming task, so I had to learn to do it myself :)
Sketchup is pretty easy program for beginners, and with a few tutorials from youtube, I managed to make this in it's raw form in just under a week! All the other measurement, color, curves, and much more corrections came a bit later with a bit more youtube tutorials :)
want to do mine for me lol. give you a little more practise :P
Subbed! Gonna be a fun build to watch.
Will this be attached to the wall? If you ever need to move or just fancy rearranging the room would it be as simple as moving a wardrobe or would it need a dismantle.
