Project 'Unnamed'
@ Anox, yeah I couldn't think of a name, and project white lightning or white whatever just seemed too easy.
@ cypto, No plans for a custom water loop really because I don't really overclock much. CPU is OC'd to a safe 4.0Ghz, and GPU is stock. If I have time to do some research on overclocking, then I might go for a nice EK setup with GPU blocks and everything.
@ acme15, Nice build m8. The 600T is a pleasure to work with.
There is one small problem though. The screws that came with the H100i stick out a bit on top, and get in the way of the top filter/panel. Only by about 2mm but it won't close properly. I'll have to try and find some flatter screws.
Also, watch this space. A couple more small mods inbound... :D
Small update. I just brought a Lamptron FC5 v2 Fan controller and some NZXT LED's. I wanted to be able to shut down the fans for ridiculously quiet operation. (Not sure how long I could get away with having the H100i fans at 0RPM, but i'll soon find out)
IMG_3976 by PMolkenthin, on Flickr
IMG_3974 by PMolkenthin, on Flickr
Pictures aren't all that exciting, but hey. Here's what it looks like running and in low light....
IMG_3979 by PMolkenthin, on Flickr
IMG_3987 by PMolkenthin, on Flickr
One thing I noticed is that one of the 120mm fans (on the H100i) is running 100-200RPM slower than the others. I think maybe it needs replacing. Or maybe some WD40 ;)
IMG_3986 by PMolkenthin, on Flickr
Nice little update, the lamptron fan controller is a nice piece of kit matches the rig perfectly with the blue display.
Going to be posting my own log soon, you should have seen my components in my old case looked seriously ghetto :D
