The main aim of this project is to have a watercooled Silverstone sugo SG03 which will be my pc for lans. The watercooling will be for CPU only and all be internal, with the only exteral part being an external dvd drive. A 240 rad with 2x 120mm fans will be mounted behind the front grill inplace of the exisitng 2x 120mm fans. To increase airflow a 120mm fan will be mounted on the top of the case. The bottom fan on the rad will interfear with the bottom hard drive mountings, so a replacement/modded part will be needed there. The front and side grills will be re sprayed blue.
Parts ordered:
Silverstone SUGO SG03 Silver
Aqua-Computer Pro 240 Radiator
Swiftech Apogee CPU Waterblock
XSPC Single 200 Bay Reservoir Pump - Clear
Yate Loon 120mm LED Blue x2
120mm AKASA Imperial Blue case fan
ClearFlex 60 3/8" tubing
PrimoChill Anti-Kink Coils 5/8"- Gloss Blue
AC Ryan RadGrillz Stripes Silver
1/4" High Flow Barb for 3/8" Tubing x6
Nylon Hose Clamp x6
Zalman RC56 (7V) Noiseless Resistor Cable x3
Akasa 3 pin Y-splitter Fan Adapter Cable
Feser One UV Blue
Gigabyte GA-G33M-DS2R
Samsung External USB2 DVD±RW
Plasti-kote Super Night Navy spraypaint
Hardware:
Intel E6600
4GB Geil PC6400 ram
Seagate 250gb 7200.10 hard drive
8800GT 512mb
Creative 7.1 se
Coolermaster igreen 600w
Next update will follow within the next few days with photos showing the start of the build.
Parts ordered:
Nylon Hose Clamp x6
Feser One UV Blue
Hardware:
Intel E6600
4GB Geil PC6400 ram
8800GT 512mb
Creative 7.1 se
looking good man.
