[Project] Watercooled SG03
I'd really like that case without the sticky outy side panel. I think it looks scruffy and really detracts from the look.
looks good man, you should mod a slot loaded laptop dvd drive into it somewhere, perhaps side ways on the front or where ever you have room.
good work anyway :p:D
nah I doubt it with 2 120mm fans on the front.
my understanding is these meshy sides can often damage your airflow, the best way to have a case is nice positive pressure pushing the air from front to back.
If you had mounted the radiator at the front with the fans behind it woulld you have been able to avoid cutting the harddrive bay?
I'm hugely tempted to buy one of these but want to plan a bit more first :)
The rad just wouldnt fit in to the front fan holder, very nearly tho must have been a few mm out width wise, but was way too long, so had to mount it via the fans.
