- 18 Mar 2008
Looking really nice mate! Let me know if your cathodes are any good. I got some AC Ryan ones and they suck balls.
..Good job Greg... although I would ditch the uv lighting... Ben and I realised the EC6 is very unreactive to UV light.
I'd rather ditch the EC6...If I were you I would just use what you have atm (i.e. the EC6) and keep the cathodes. In 3 months time, change your fluid to distilled water with a dye that is UV reactive. That means you will be able to use the cathodes but you wont have to wait any longer to finish the buildBut I spent a tenner on it!I'd rather ditch the EC6...
If I were you I would just use what you have atm (i.e. the EC6) and keep the cathodes. In 3 months time, change your fluid to distilled water with a dye that is UV reactive. That means you will be able to use the cathodes but you wont have to wait any longer to finish the build![]()
well, most people seem to think that the premade coolants are the biggest problems as the clog everything. Yes dyes stain and after a while start separating but the dont clog anything and are loads cheaper.That would be a good strategy but don't dyes get really messy (start seperating) and stain everything?
.. any tips?.His barbs are due for tomorrow so he will finish it off then if he canany more pic soon?... i will be starting my water cool on my k-62 with in the next few weeks.. any tips?.
His barbs are due for tomorrow so he will finish it off then if he can![]()
... I should be getting all my stuff 2morr in the post to start my water cool system
More photos soon
... I've got all my stuff now ready for my water cool, I just need to send my case off now to be powered coated ready for it all
I think I am more excited than he is lolYAY!!!!Nahh I will have photos up tonight!!!1!
