- 31 May 2006
- West London
Y-Flow
Two fan cooling with a non-traditional twist - they are both exhaust.
Should have this finished tonight (after doing two days of fan tests)
Start with a simple case mod - add a fan hole.
Measure
Dremel to start - much harder cutting steel that aluminum
Hacksaw time
Make sure your hacksaw has a rotating blade, makes life much easier
Grind down the extra metal
Finishing touches to remove any sharp edges
Remove all the metal filing - don't want any shorts
Now to invert the case...
Measure
Hacksaw time
