- 14 Dec 2005
- Bath
Need to buy a projector (more for business/presentation use than home cinema) so thought I'd ask the knowledge of OcUK
(btw, anyone know any decent business/presentation projector forums/review sites?)
The budget is £1500 inc (max max) and it will be used in a quite bright room, and I reckon should be LCD. The current projector is an 800x600 1500lumens InFocus, and tbh is crap
I've found the Sony CX155 for £1313.12, which is 3500Lumens and 1024x768 (will display/compress 1400x1050) and was wondering if anyone here has any experience of the Sony CX range?
The only concerns about that projector is it's not DVI (my MacBook Pro will be one of the main laptops used with it) but I guess it'll work with a DVI-VGA adapter
(the one Apple ship the MBP with) Other concern is that 1024*768 is imo quite a low resolution
Soo, does anyone have any suggestions of a projector with higher resolution/DVI for (upto) £200 more than the Sony CX155?
TY All....
(btw, anyone know any decent business/presentation projector forums/review sites?)The budget is £1500 inc (max max) and it will be used in a quite bright room, and I reckon should be LCD. The current projector is an 800x600 1500lumens InFocus, and tbh is crap
.I've found the Sony CX155 for £1313.12, which is 3500Lumens and 1024x768 (will display/compress 1400x1050) and was wondering if anyone here has any experience of the Sony CX range?
TY All....
