[Prolog] Help!
1 Feb 2006
Reading
First of all id like to register my absolute disgust for this language, it's so frustrating.
Anyway. Basically I'm trying to use a recursive procedure and for some reason it never ends.
The task is on a 3x3 grid move from location X1,Y1 to X2,Y2, logging the steps taken in Path.
Code:
simple_move(at(X1,Y1), at(X2,Y2),Path) :-
    map_size(Map),                                  %size of map
    X1\=X2,                                            %check if found X value
    XStep is (X1+1) mod Map,                    %step right one space
    cost(at(X1,Y1),at(XStep,Y1),Cost),       %determine cost of step
    append(Path,[step(at(X1,Y1),at(XStep,Y1),Cost)],New_Path),    %add step to list of previous steps
    simple_move(at(XStep,Y1),at(X2,Y2),New_Path).  %make next move
It executes ok but when it comes to the termination clause, X1==X2 it fails as expected, the recursive iteration fails, but then it calls a redo on something and carries on!
Any ideas?
