Pros and cons of SQL?
3 Apr 2003
Hey guys,
Got an essay to do (well its only 500 words) about the pros and cons of SQL, somehow i have to fit this into 500 words which is going to be the challenge. I have no SQL experience at all as am only just starting a database module at uni, figured asking anyone with experience here for some pointers couldnt hurt. Not looking for a load of info to steal am just wondering what you would consider to be the BIGGEST pros and conns of SQL so that i know where to focus my research.
Cheers all
Bit of a dumb question.
Pros are obvious.
For cons I'd probably focus on backwards compatibility and security.
500 words is nothing, so I don't rly see the point of this exercise.
They probably mean the pros and cons of SQL as a Structured Query Language.
Look into why its used for DBMSs' and not much else. What is the reason for SQL. Why not used elsewhere. Why are there so many different standards/versions per vendor.
I'm assuming stuff like that will highlight some pros and cons.
very helpful, thank you.
unfortunately to the one above, I can't just tell them it's pointless and not do it. Nor just write any old 500 words which is indeed easy. This counts towards my degree so I want to put effort and time into everything no matter how small.
Thanks again
SQL's flexibility is both it's greatest strength and it's greatest weakness.
If you know what you're doing and understand the data it's great. If you don't then you can easily write something which will just chew resources on the server and probably give the wrong answer.
Pretty much this, its easy to do good stuff with it. Its even easier to break whole applications!!
The main cons are the many different standards/versions per vendor.
ANSI 86 is probably the most backwards compatible version. Now, its not very portable due to all the specific vendor specific additions.
pro: good for returning relation data from a database
con: not very good at making a cup of tea
There must be some more context to the question? In terms of other programming languages? or in terms of things like object/relational impedance? (I suspect it won't be the latter).
Just "SQL" or a specific flavour of SQL?
Do they mean things like a lack of control of flow? variables? that sort of thing?
To be honest, I've been writing T-SQL for so long I can only vaguely remember what standard vanilla-flavoured SQL does and doesn't have...
Object relational impedence mismatch is the biggest problem. That and its ACID transactional nature means it doesn't scale out.
Optimised for storing structured data with defined relationships, requires understanding of set theory. Can be difficult to maintain if normalise too much or too little. Some performance implications may not be understood at design time, and prohibitive to engineer out later. Poor choice for storing unstructured data, documents. Modern OOP software often emphasises compound objects which may not be a good match with SQL. Foreign keys can enforce referential integrity. Transactions are important, again for maintaining known state an data integrity. SQL skills are widely available, as is ecosystem of tools to produce useful reports.
Pick a few if those points, write a paragraph on each and avoid straying from SQL an into the underlying DBMS.
For context, assume you are comparing SQL to alternatives - document stores like Mongo, KVP stores like Redis and serialisation of complex data types to files on a disk.
Awful question,
SQL is rubbish for brushing my teeth with....
As previously said, advanced queries without calling indexes on tables containing vast amounts of data (try selecting one single row on a table of millions, where the col1 = varchar (e.g. 123456 and you search using 123456 as a number, the system is going to have to convert the whole table for the search string, hence massive overheads)
