Proxy loading pages faster than directly...
17 Aug 2009
Just updated my routers firmware (Netgear WGR614v7) which seems to have helped a problem with searching for servers on steam.
But now, inexplicably, OCUK forums are incredibly slow. Doesn't seem to be any others, just OCUK :/
A traceroute ends up with the last few jumps timing out and a web proxy can load the pages in 2 seconds while trying to load them without takes at least 20. Very frequently getting "taking too long to respond" error pages too.
Any ideas on sorting this :confused:
Web proxies usually cache, so that's likely to be why it's loading quickly.
Check your dns settings, try open dns, see if that makes a difference
The firmware upgrade was done according to the manual including resetting it after the update.
I've gone back to the original and things are working fine again, I think I'll live with steam server searching being dodgy.
