PS2 on a monitor?
9 Oct 2006
Location Location!
I am sure this is possible but I can't seem to find any information about it.
I have a PS2 in my room but no TV, I do however have a monitor which has VGA/DVI input. I heard they are called modularisers or something along those lines which change the signal frequency and allow it to be output on a monitor?
Help here would be appreciated as both screen and PS2 are getting dusty :)
ps2 will look shocking on a high res screen.
as i found out when linking it to a 720p tele.
yeh look on ebay LOgic3 VGA Box, Play PS2, PS3 Wii Xbox on VGA Monitor box to attach your consoles to TFT.
I figured it would look bad, but then i'm not playing at point blank range. Hoping it will be ok I know its not exactly a 360.
Ty andrew I will do that :)
used to have one you see for my ps2 slimline. Great piece of kit.
