Thinkin about gettin a ps3 soon, would love to play it on my monitor, but can i??
here's the specs thats on the monitors webby,
Medion 22"
* Visible screen diagonal 55.8cm
* Brightness typ. 300cd/m2
* Multilingual on screen display
* Integrated power supply
* Low radiation accordingly to TCO 03
* Viewing angle: horizontal 178°/vertical 178°
* Maximum Resolution 1680 × 1050
* Response Time typ = 5ms
* DVI-D and VGA Interface with HDCP Encryption and Automatic Signal Detection
* Contrast Ratio = 1000:1
* 2 Built-in Speakers
* Dimensions: 397 (H) × 524 (W) × 224mm (D)
is it just the case od plugging in a cable to the monitor and away i go?? if so how much would i be lookin at payin for one of these cables?
thanks for the help folks!
Medion 22"
