Looking at the Sony Bluetooth Wireless Keypad. Had a keyboard plugged in most of the time but was interested in replacing it with this. Does it come with a dongle that plugs into a USB port or does it just work? Anyone got one? They worth the £20?
i have a dell bluetooth keyboard, how would i go about connecting it with the ps3?
I have one of these
http://www.logitech.com/index.cfm/gaming/playstation_3/keyboards/devices/3616&cl=gb,en
Works brilliantly - including the mouse pad on the right - just need firefox for PS3 and life would be perfect
Rich
Costs like 5 times more than the PS3 keypad tho![]()
More like twice as much to be fair; I've seen it around for £30...
Personally I'd rather have the full sized keyboard for the extra money, but each to their own![]()
It's Bluetooth (like the headsets and controllers) so it doesn't need any dongles. It comes a with a USB cable so you can pair it easily (you just USB to PS3 once and it is paired) and you use this to charge teh built in rechargeable battery as well. It auto turns off or standby's so the battery lasts a very long time imo.
I have one, and think it is worth it, if you use the keyboard a lot, you will use this a lot. Take a bit of getting used to where the extra symbols and stuff are, but you can type fast once you learn.
rp2000
