- 8 Dec 2002
- North Yorkshire
Can you use any USB headphone and mic ?? or does it have to be a certain type??
Anyone recommend me one??
It has to be bluetooth, doesn't it?
I'm not sure,looked on google but the answer doesn't seem to be clear. Can anyone help??
Most USB headsets ive used on a PS3 work first time with no issue's just have to be set up in the XMB. I use a Skype one got it from a catalogue shop for £20 its works well and is comfortable, could get on with a BT headset it kept falling off my ear.
funny you should day that , there the ones I was looking at.
Anyone help witht he streaming of the music at all?
No it doesnt, im using a Logitech USB headset and it come through pretty much as clear as skype.
I think McManicMan recommends the Logitech Vantage USB headset.
you won't get sound effects through the headsets its for voice communication.
