Deleted member 651465
Hey all,
Connected the PS3 to the Wireless network (no security), all works fine when it does a connection test but then after about 2-3mins I get a pop up saying "you have been disconnected from the access point"
It will reconnect fine, and I can load the WWW browser, but then SAME PROBLEM again!
I've tried setting a static IP, using an auto detect but nothing works for longer than 2 minutes (if that).
Anyone got a suggestion??
