Hi all,
Some boring reading for some possibly.... so my apologies now
Anyway, i am having an ongoing battle at work with 2 360 owners & me being a PS3 owner.
They keep telling me that the xbox 360 is far superior in terms of games.
They have given me the multi media star due to bluray & other fancy stuff.
But its the games side of things we're really arguing about & specifically whats more powerful.
I always thought that the PS3 being newer kicked butt here but reading the below would appear not.
Can someone have a read & respond in a unbiased way. I have no problems if in fact the 360 is superior, I've made my bed & bought the PS3 when it originally came out for 400+ bucks (I know) but the bigheadedness of the guys at work is driving me insane.
So my question - which is better for gaming. Not what has the best developers or back catalogues etc but which can be push the envelope futher if given the right input.
Below is what he Mr 360 sent me to rub it in...........
Let's look at the maximum theoretical numbers for the Xbox 360 and PS3 GPUs.
Triangle Setup
Xbox 360 - 500 Million Triangles/sec
PS3 - 275 Million Triangles/sec
Vertex Shader Processing
Xbox 360 - 6.0 Billion Vertices/sec (using all 48 Unified Pipelines)
Xbox 360 - 2.0 Billion Vertices/sec (using only 16 of the 48 Unified Pipelines)
Xbox 360 - 1.5 Billion Vertices/sec (using only 12 of the 48 Unified Pipelines)
Xbox 360 - 1.0 Billion Vertices/sec (using only 8 of the 48 Unified Pipelines)
PS3 - 1.1 Billion Vertices/sec (if all 8 Vertex Pipelines remain)
PS3 - 0.825 Billion Vertices/sec (if downgraded to 6 Vertex Pipelines)
Filtered Texture Fetch
Xbox 360 - 8.0 Billion Texels/sec
PS3 - 13.2 Billion Texels/sec (if all 24 Pixel Pipelines remain)
PS3 - 11.0 Billion Texels/sec (if downgraded to 20 Pixel Pipelines)
Vertex Texture Fetch
PS3 - 4.4 Billion Texels/sec (if all 8 Vertex Pipelines remain)
PS3 - 3.3 Billion Texels/sec (if downgraded to 6 Vertex Pipelines)
Pixel Shader Processing with 16 Filtered Texels Per Cycle (Pixel ALU x Clock)
Xbox 360 - 24.0 Billion Pixels/sec (using all 48 Unified Pipelines)
Xbox 360 - 20.0 Billion Pixels/sec (using 40 of the 48 Unified Pipelines)
Xbox 360 - 18.0 Billion Pixels/sec (using 36 of the 48 Unified Pipelines)
Xbox 360 - 16.0 Billion Pixels/sec (using 32 of the 48 Unified Pipelines)
PS3 - 17.6 Billion Pixels/sec (if all 24 Pixel Pipelines remain)
PS3 - 13.2 Billion Pixels/sec (if downgraded to 20 Pixel Pipelines)
Pixel Shader Processing without Textures (Pixel ALU x Clock)
PS3 - 26.4 Billion Pixels/sec (if all 24 Pixel Pipelines remain)
PS3 - 22.0 Billion Pixels/sec (if downgraded to 20 Pixel Pipelines)
Multisampled Fill Rate
Xbox 360 - 16.0 Billion Samples/sec (8 ROPS x 4 Samples x 500MHz)
PS3 - 8.8 Billion Samples/sec (8 ROPS x 2 Samples x 550MHz)
Pixel Fill Rate with 4x Multisampled Anti-Aliasing
Xbox 360 - 4.0 Billion Pixels/sec (8 ROPS x 4 Samples x 500MHz / 4)
PS3 - 2.2 Billion Pixels/sec (8 ROPS x 2 Samples x 550MHz / 4)
Pixel Fill Rate without Anti-Aliasing
Xbox 360 - 4.0 Billion Pixels/sec (8 ROPS x 500MHz)
PS3 - 4.4 Billion Pixels/sec (8 ROPS x 550MHz)
Frame Buffer Bandwidth
Xbox 360 - 256.0 GB/sec (dedicated for frame buffer rendering)
PS3 - 22.4 GB/sec (shared with other graphics data: textures and vertices)
PS3 - 12.4 GB/sec (with 10.0 GB/sec subtracted for textures and vertices)
PS3 - 10.0 GB/sec (with 12.4 GB/sec subtracted for textures and vertices)
Texture/Vertex Memory Bandwidth
Xbox 360 - 22.4 GB/sec (shared with CPU)
Xbox 360 - 14.4 GB/sec (with 8.0 GB/sec subtracted for CPU)
Xbox 360 - 12.4 GB/sec (with 10.0 GB/sec subtracted for CPU)
PS3 - 22.4 GB/sec (shared with frame buffer)
PS3 - 12.4 GB/sec (with 10.0 GB/sec subtracted for frame buffer)
PS3 - 10.0 GB/sec (with 12.4 GB/sec subtracted for frame buffer)
Shader Model
Xbox 360 - Shader Model 3.0+ / Unified Shader Architecture
PS3 - Shader Model 3.0 / Discrete Shader Architecture
Xbox 360 has the advantage in most cases.
Triangle Setup
Shader Model
