PS3 - Power Supply "Sizzle?"
Permabanned
15 Nov 2006
Anyone else got a problem with the PS3 sizzling a bit if you move it slightly? The power cable doesn't fit in too well on mine and the slight knock makes it sizzle a bit.
Bit worrying anyone else got the same?
havent noticed on ps3 (dont think ive ever moved it when on ) but my pcs have always done what you describe . think its just kettle leads in general
I think its when electricity jumps to the metal connectors if there's a gap.
May be wrong.
My xbox does the same when i pull the kettle lead out of the brick.
Josh
May be wrong.
Josh
Yeah my original Xbox did it all the time :@.
Nanoman said:
Mine fits pretty snug tbh, but sizzling does suggest lose cable - not making full contact. Hammer it in?? :p
Oh god you was right I just pushed it as hard as I could and it finally popped in, it's in nice and tight now. No pun intended. :D
Sparking indicates a loose connection as you've already gathered. No new product should spark so easily and so it isn't normal for your PS3 to do this.
This is because the IEC connector is wiggling and causing it to spark :eek:
Happens if you wiggle any IEC connector.. if it's that loose I'd consider buying your own or perhaps asking Sony to replace the PS3, although I don't know what they'd say to that.
