ps4 controller pc compatible :D
It would be great if it works. Currently use the 360 pad, but its a bit of a pain when playing a game on the PS3, then I buy it for the PC and have to adapt to using a different pad. Often press 'A' when it comes up on screen to press 'X'etc. Plus I just much prefer the Playstation pads. Hopefully the PS4 pad is even better!
Don't use Motionjoy for your PS3 DS3 controller on PC, the program is hideous. Instead get the drivers from Motionjoy and then get a program called Better DS3.
There is a vid on youtube with download links but you need the drivers folder from Motionjoy (32 or 64 bit), google will find them too. Update the driver for the controller in device manager and then run Better DS3 to emulate the controller. So much better and works great with emu..., ahem I mean elevators ;) :D
Tried this and I cant get my pad to show up in Better DS3
Sorted was using a older driver.
