- 21 Jul 2007
- Newcastle upon tyne
Hi all
Getting a PS4 pro tomorrow and need advice on airflow.
It will be going into a tv unit that only has a little hole for the wires to pass through. I know this will be an issue for cooling the console to iv been looking into getting the heat away.
Pictures to show. The Wii will be moved out.
[/URL][/IMG]
I was thinking of getting 2 80mm AC infinity fans and putting them on top at the back of the PS4 to push the heat out the front.
Or putting a fan as a exhaust on the back of the unit.
Ideas?
Thanks!
Ideas?
Thanks!
