PS4 Pro power cable...
14 Jan 2004
Reading, UK
Howdy folks,
The power socket on my UK PS4 Pro (not imported or anything) is the size/shape of a kettle socket, but has only the left and right pins.
Does anyone know if I can use a regular 3-pin kettle lead to supply power to it?
Cheers!
I've had a quick mooch on Reddit, apparently you can. The missing pin is for ground so it shouldn't cause any problems. Disclaimer - you try it at your own risk. :p
Don't think that's the right plug type.
I'd recommend getting the correct cable instead of getting something that "could work", it's likely it will... but I'd hate to read something happened.
It will work absolutely fine. The earth wire just won't be connected to anything.
