Without a bank account or a car how are you going to achieve this mission?
I have bothI would get a series s + gamepass as they are pretty cheap and have more 60fps support + resolution boosts on older games.
He already has a Slim PS4 which plays the same games at the PS4 Pro so he's not missing out on any game by going the XBox route, and would be gaining access to hundreds of games via Game Pass and the XBox exclusives.
It definitely seems to be the smart way to go as the PS4 Pro still has a massively crippled CPU that stops games from having significant and stable frame rate increases over the Slim.
I dont like xbox
I’d personally just wait and use the money spent on trading for a ps4 pro on some ps5 games once you get one.
Availaibilty will get better…
It's a plastic box with bits that go beepboop on the inside...do you mean, you don't like any of the games available, or do you literally dislike said box?I dont like xbox
I just don't like the controller and dashboard. Not played on one since 2005It's a plastic box with bits that go beepboop on the inside...do you mean, you don't like any of the games available, or do you literally dislike said box?
