Ps4 wireless adapter....hmmm
30 Oct 2014
Norfolk
So I impulsively bought the ps4 wireless adapter..to hopefully play cuphead via my pc with it. Turns out its only for ps4 services like ps now..ugh. I didn't read too much into it, thought itll be as simple as that.
Coudn't find much online for the fix, dont think there is, but should i return the adapter..and buy a xbox 360 wired controller. Or has someone found a way to map the buttons so games recognise the controller, honestly i dont love the xbox controller feel lol.
Does ds4windows still work ? I used my DualShock with that app and it worked flawless.
Edit. Works with any Bluetooth adapter apparently
Plug the charging the cable into the pad and use that steam supports the PS4 pad if its a none steam game download ds4windows
I bought a £3.99 blue-tooth dongle for my PC that connects the PS4 pad perfectly. Some of them just flat out do not work but a quick google search will tell you before you buy.
