Ps5 connected to my WiFiIs this over your local network? Do you have VLANs or multiple networks? Thought I'd ask as I've had friends who overlooked these.
Look forward to your update and how toSlight aside but I got a portal the other day and struggling with connection at home. Have my ps5 using ethernet (via powerlines) and am next to the router. Setup a 5Ghz wifi channel but connection isnt great even being so close to the router. Will do some more fiddling tonight but if its not better its going back sadly.
Are you using a portal?Look forward to your update and how to
Overcome it
No iPhone or iPad with remote play app if that doesn't work I won't bother with portalAre you using a portal?
Powerlines can be very inconsistent in terms of throughput, they aren't necessarily much better than WiFi.Slight aside but I got a portal the other day and struggling with connection at home. Have my ps5 using ethernet (via powerlines) and am next to the router. Setup a 5Ghz wifi channel but connection isnt great even being so close to the router. Will do some more fiddling tonight but if its not better its going back sadly.
My portal is fine with both my PS5 and my Portal on the same WiFi network.Slight aside but I got a portal the other day and struggling with connection at home. Have my ps5 using ethernet (via powerlines) and am next to the router. Setup a 5Ghz wifi channel but connection isnt great even being so close to the router. Will do some more fiddling tonight but if its not better its going back sadly.
