PSN Network Problem
19 Mar 2006
Scotland, UK
Been having this problem since I done the last Playstation update!
I am using a wired connection from my PS3 to my O2wireless box (version 1) and I am able to get an internet connection (can use the playstation web browser fine) and a connection to my PC (PS3 Media Server).
I cannot however login to the PSN network to play games, all i get is An error occurred during communication with the server, this is a DNS error. (80710102)
Any ideas?
Sadly, the problem is now widespread, mainly on Sky/O2 broadband network.
This only arised since the new PS3 Firmware update. I would recommend changing the DNS manually to DNS1 4.2.2.2 DNS2 4.2.2.3, as this is known to fix the connection problem.
Hope this helps
I've always used openDNS, I find them much better than Default ISP DNS server.
So i recommend the change whether you have problems or not, Even if you dont have a console and just a PC, CHANGE CHANGE CHANGE*
*if you change and are unable to connect to the internet, please note i am not responsible, and you should not in anyway attempt to cause me physical harm
