- 30 Jul 2007
Looking for some advice please on new purchase in the next month or so. (in uk from ocuk)
for [email protected],1xGTX970,10x5400rpm sata (in 3,3,4 configuration),1xSSD,Asus X99-S,Cosmos II Case (V. Large Case), Air Cooling.
Priorities are (highest to lowest) Lowest Noise, Value (over 10 Years), Efficiency @ low loads, Price (Over 10 Years)...and that that the cables eg, ATX fit neatly around the back of board (ie are long)..Warranty (albeit it does go to value somewhat)
The server/gaming pc is on 24/7 and estimated to consume 75W at idle (it never sleeps), a state which it is 75% of time.
I entered the hardware into http://extreme.outervision.com/psucalculatorlite.jsp
and 530 Watts is recommended.
What PSUs would people recommend please?
points im musing over are...
Do i have to buy more Watts to get more quiet. looking for as close to silence at idle as possible and quiet at load.
Am i right to think more Watts is less efficient..Eg a 750W PSU would be 10% utilised @ idle which equates to a poor efficiency rating on PSU (unless titatium rated), a 1KW would be even less efficient (as even lower load at idle).
Am i right not to worry about how many sata cables come with unit, i can buy a 4 port extension for £5.
Needs to not exacerbate 970 coil whine.
thank you
thank you
