6 Nov 2007 at 19:33 #1 AlanJ AlanJ Associate Joined 16 Nov 2005 Posts 683 Location Torquay Hi all, Just need a little bit of advice please. I'm in the process of building a new computer. Intel bad axe II E6700 want to overclock slightly 8800GTS OC 640mb 4gig ram dvdwr 250hdd Would a Hyper typeR 480Watt psu be OK?
6 Nov 2007 at 19:38 #2 BENdage BENdage Associate Joined 15 Jan 2004 Posts 2,190 Location My Chair, Peterborough Doubt it, the Hipers have a bit of a rep for dying when under strain. I wouldnt risk those components. Get yourself a new one, at least 500W
6 Nov 2007 at 19:40 #3 BillytheImpaler BillytheImpaler Man of Honour Soldato Joined 2 Aug 2005 Posts 8,720 Location Cleveland, Ohio, USA Corsair HX 520 Hiper had a very bad run with that particular 480 W model. A great number of them experience premature failure.
6 Nov 2007 at 19:44 #4 AlanJ AlanJ Associate OP Joined 16 Nov 2005 Posts 683 Location Torquay Cheers for the advice lads would this one here be ok ? The price seems ok http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OC
6 Nov 2007 at 19:48 #5 BillytheImpaler BillytheImpaler Man of Honour Soldato Joined 2 Aug 2005 Posts 8,720 Location Cleveland, Ohio, USA Yeah, it'd do just fine, though the Corsair would be quieter.
6 Nov 2007 at 19:57 #6 pastymuncher pastymuncher Man of Honour Joined 12 Jul 2005 Posts 21,873 Location Aberlour, NE Scotland Jestergt said: Cheers for the advice lads would this one here be ok ? The price seems ok http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OC Click to expand... No, the OCZ's are not very good either. The ripple is very bad amongst other things. I have also had a 700w GameXstream fail after only 3 months.
6 Nov 2007 at 20:04 #7 BENdage BENdage Associate Joined 15 Jan 2004 Posts 2,190 Location My Chair, Peterborough Get the 520W Corsair. Apparently they're the best at the mo. Always get great reviews
