Two things to start with.
1. I've checked many PSU calculators and have been given many different answers as to what I should buy. Quite a few say that every GPU need 150W, with no change in Watts when I change to another GPU.
2. Sorry for all the Amazon links. Everything was chosen from there.
So, this is the hardware I'm planning to get with the option of adding another GPU at a later date.
Case;
Corsair CC-9011030-WW Carbide Series Air 540 ATX High Airflow Cube Performance Windowed Computer Case - Black
Motherboard;
MSI X79A-GD65 (8D) Motherbaord (Core i7, Socket LGA2011, Intel X79 ATX RAID, Gigabit, LAN)
CPU;
Intel Core i7 4820K Extreme Quad Core CPU Retail (Socket 2011, 3.70GHz, 10MB, 130W, Unlocked and Unleashed, Hyper-Threading Technology)
Cooler;
Corsair CW-9060016-WW Hydro Series H105 240mm Rad Extreme Performance All-In-One Liquid CPU Cooler
RAM;
Corsair CMZ8GX3M2A1600C9 Vengeance 8GB (2x4GB) DDR3 1600 Mhz CL9 XMP Performance Desktop Memory Kit Black
GPU;
Asus GTX 770 Nvidia GeForce DirectCU II OC 2GB GDDR5 Graphics Card (PCI Express 3.0, HDMI, DVI-I, DVI-D, Display Port, 256 Bit, 3D Vision Ready, GPU Boost 2.0)
2x SATA HDD
1x SSD
There are two PSUs that I've look at getting;
The first being a 750;
Corsair Builder Series CXM 750W Modular 80 PLUS Bronze Certified ATX/EPS PSU
If that's not sufficient, then I was going to go for the 850;
Corsair CP-9020056-UK RM Series RM850 80 Plus Gold 850W ATX/EPS Fully Modular Power Supply Unit
If anyone could point me in the right direction, I'd be very much appreciated! Thanks.
EDIT:
Sorry, removed! I'll edit again and give the full names of the products.
Case;
Motherboard;
CPU;
Cooler;
RAM;
GPU;
2x SATA HDD
1x SSD
EDIT:
PLEASE REMOVE THE COMPETITOR LINKS AS THEY ARE AGAINST THE FORUM RULES!!!!
http://forums.overclockers.co.uk/faq.php?faq=vb_read_and_post#faq_vb_special_codes
