Psu and cpu cooler
3 Jan 2003
purchased most of the parts to build a HTPC
E5300
ASUS P5N7A-VM LGA 775 NVIDIA GeForce 9300/nForce 730i HDMI MicroATX MB
compro 350 freesat card
500gig HD
bluray drive
my old freeview usb tuner (will be replacing it with a pci one at some point)
silverstone LC17B HTPC case
how good is the stock cooler on the E5300? it's much smaller than the stock cooler that came with my E2160! and is it quiet?
also looking for a good and quiet PSU around £50
maybe this one OCZ ModXStream Pro 400w Silent
cheers
Topher
Power supply either the one i posted earlier (which is very good and quiet as hell) or the Corsair CX 400W. But seriously, the cooler i posted is a steal at that price. Go for it.
I'd of thought the OCZ and corsair would be quieter than the "PC Power & Cooling Silencer 420W" due to the difference in fan size? another reason I went for the OCZ is because it's modular.
The PC P&C will be quieter, it's only measured by them to be about 10dB. It's also a larger wattage, and can go up to 480W. Definitely the budget PSU of choice at the minute.
end up getting the mini ninja and corsair hx450w, hope the hx450 is as good/quiet as the hx520 ;-)
haven't had chance look at the mini ninja but I am guessing it comes with a thermal pad, should I remove it and use some artic silver 5? which is what I normally use..
cheers
