PSU cable length / case size question..
8 May 2008
Sunny Devon
This is sort of a case question, sort of a PSU one..
I need to upgrade to a full size case, my current build is literally crammed in to my old Tsunami and its causing all sorts of problems.
My PSU is a 3ish year old OCZ Modstream and doing a fine job so I don't want to buy a new one. But I'm worried about the length of the cables and if they will be long enough to reach the optical / hard drives in the Antec 1200 I'm looking at buying.
Does anyone know if cables are longer on newer PSUs or will mine be ok? Or of anywhere I could buy replacement cables for the modular part of my PSU if mine aren't long enough?
Cheers
