PSU cable lengths for full tower case
19 Jun 2012
Hi all
I am looking at biting the bullet and getting a new case (800d) so I can run Crossfire but I am just wondering about cable lengths.
I am considering the Seasonic X850 but need to know if the cables are going to reach on an Asus P8Z77-V LX board without needing extensions? I am intending to make it tidy and run the wires around the back of the motherboard tray etc. I have done a bit of googling and found that most of the main cables are listed as being about 55-60cm long. Will that be enough inside that case?
Cheers
Buff
What case do you have now?
If it's big enough for what's in your sig then I assume you can fit CrossFired cards in there.
If you're sticking with air cooling then I believe the 800D isn't the best choice. It's better for watercooling.
The motherboard in your sig runs the second x16 slot at x4 speed which may have a small impact on performance.
currently have an Antec BFG900.
I will be sticking with air cooling yes.
In real life use, how much of a performance drop will it be?
Is see from your other thread (Antec BFG 900 crossfire) that it's perhaps not the best case for what you propose.
From what I've seen on this forum there are better cases than the 800D for air cooling.
The performance drop from running CrossFire at x16/14 instead of x8/x8 can be anything from virtually nothing to 25% with HD 6950s depending on the game: Does CrossFire Work At x16/x4?
The drop probably isn't as high with the HD 6870.
