psu choice (modular)
4 Apr 2003
Manchester
I fancy a new PSU, preferably a modular one as my case is going to be a little cluttered and I can't afford to have wires that aren't being used in there.
will need connectors for
mobo - currently dfi nf4 ut but probably be a conroe board very shortly
x1900xt
2 x optical drives
1 x ide hdd
4 x sata hdd
1 x molex for fan controller
1 x molex for prommie
Will be oc'ing heavily
I liked the look of the modular tagan 580w but it doesn't have enough connectors so I guess I will need to use splitters?
Are there any with loads of connectors or better priced?
Given the amount of gear in there, should I forget the modular route?
Current PSU is enermax 460w 28a on 12v
Ive got the tagan 580w and im fairly sure there enough connectors for what you need, if not use a splitter on the 2 optical drives.
ArchAnGeL said:
{snip}Given the amount of gear in there, should I forget the modular route?{snip}
YES... because of that & also I've heard some people say modular hasn't made a difference in terms of tidiness :(
Most effective way is if your case allows you to hide cables use that with some cable ties :cool:
The 580w Tagan (non-modular) has about 8 HDD molex connectors :eek: Might need to get a-few splitters, though recommend a beefier PSU considering the X1900XT in there :)
I agree with the above, it dosent make thinkgs much tidier as some of the cables arent really flexible enough, like the pci-e connectors
The Case is the issue now really. I bought the prom with the aim getting rid of one of my pc's. The easiest way would be to use my pc60 case and cut a hole in the bottom. But it's cramped as it is.
The other case is a pc70 which is huge but will require some modding as I doubt the prom will fit underneath and reach the cpu socket.
Can't really afford a new (decent) case as after just buying the prom, I am also looking at a new cpu, mobo, ram and psu although I do have some decent stuff to sell.
What size psu do you recommend if the 580w is innadequate. My enermax has been fine with a 3500 @ 2.6, 1.55v, 1 optical, 1 sata and the x1900xt.
I suppose the other option, if I use the pc70, is to use 2 psu's as I have 2 of the enermax's. I guess one for all the mobo connections and one for the drives and x1900xt. May be a better solution as i want to add a watercooling loop for the x1900xt and NB later on.
How do it wire them so they both come on when the power button is pressed?
ArchAnGeL said:
or what do we think of this one?
Thermaltake PurePower 680W ATX2.0 Power Supply (W0049) (CA-021-TT)
Thermaltakse's not to sure, also not that reputable. Stick with the known brands like Tagan.
As for 2 PSU, I know people run them but there's some caution. Wait for the real experts on that ;)
What's making it tight, is the extra HD's, use this to guide you :cool:
ok, it's up to 521w with 4 hdd and say a 3800x2 at 3 gig and 1.7v which is a potential intermediate upgrade for me.
So really a 600w+
I could get down to 3 hdd's but it doesn't know much off.
ArchAnGeL said:
the next tagan up is the 900w which is a bit pricey.
Any other suggestions or opinions on the thermaltake's
Ok, mistake everyone makes with that calculator is that they fail to see that its with everything running at 100%, which in my opinion is rare! The 580w Tagan will do, since they, unlike other PSU makers don't rate their supplies at peak W's (hence why there's no 600+W Tagan PSU) :cool:
