Hi,
Wonder if anyone could shed some light on this.
Checking my voltages by Sandra Pro Lite 2008.
+3.3v reads 3.29v
+5v reads 5.08v
+12v reads 6.04v
It is the 12v that concerns me. Is that ok? In BIOS on boot up, it reads as 12v.
The PSU is a 500w EZCool.
The system is an Abit SLi mobo with an E6550 Processor. 4 Hard Drives, DVD Writer, 8600GT 256MB SLi ready GFX Card.
The MOBO Power config is 20+4 and 8 pin socket to power the CPU (with a 4 pin connected). There is a molex connector for powering the PCI-E, which is connected.
Just a bit concerned incase the 12v could damage anything as I would hate anything to blow or fail.
Thanks
+3.3v reads 3.29v
+5v reads 5.08v
+12v reads 6.04v
Thanks
I have checked this out with Everest and that reports 12v. Will borrow an MM from someone I know. Have to admit, I am far from happy with this build though. The Akasa HSF seems to get loose very easy. Doesn't seem to attach very well to the mobo and it is quite heavy. Just catch it, and its loose. It just uses the standard fittings like the Intel HSF.
